LabWindows/CVI
sound card voltage
hello i was wondering if there are any examples that let you measure voltage from a standard sound card?  or if not, if there is something close that would allow me to do this.
(3,958 Views)
Hey ACgraham,
What kind of DAQ card do you have in your system?
Or are you trying to measure the voltage in the sound card using just LabVIEW?
Nick
(3,927 Views)
Accepted by topic author acgraham
Hi nick, possibly acgraham is just trying to access the sound card from CVI Smiley Wink
Normally I consider that a DAQ card is much more flexible than a sound card, which higher input voltage range, a large set of acquisition modes and examples and not so high costs (at least, some low-cost devices can be purchased like 6008 or 6009). Nevertheless there is the possibility to access the sound card: you can read this discussion as an example.
(3,907 Views)
