12-11-2009 07:22 AM
Solved! Go to Solution.
12-14-2009 11:10 AM
Hey ACgraham,
What kind of DAQ card do you have in your system?
Or are you trying to measure the voltage in the sound card using just LabVIEW?
Nick
12-15-2009 12:32 AM
Hi nick, possibly acgraham is just trying to access the sound card from CVI ![]()
Normally I consider that a DAQ card is much more flexible than a sound card, which higher input voltage range, a large set of acquisition modes and examples and not so high costs (at least, some low-cost devices can be purchased like 6008 or 6009). Nevertheless there is the possibility to access the sound card: you can read this discussion as an example.
