LabWindows/CVI
\033 escape codes for ring items
Hi
I am using CVI 8 and I'm trying to arrange the labels of a ring control in columns, the \033 p(ixel) codes don't work though. Is there any other way to achieve that?
thanks tons in advance!
(3,140 Views)
You cannot organize ring elements in columns: this option is intended for list boxes only. The only active escape code for ring controls is \033m- to insert a separator between two elements of the ring.
One possible alternative is to use a monospaced font and embed spaces inside the text to mimic column alignment.
(3,128 Views)
