LabWindows/CVI
A function for TS result Update
Could anybody suggest a generic function that could be used to update pass/fail test, numeric test, multinumeric test results to teststand report generation in LabWindows? The function could be void reportResult(tTestData *testData, tTestError *testError)
(3,620 Views)
Hi:
Activex controller "ni testand ui controls 3.1" maybe have some using about it .
Sonic
Sonic
Diffrent Strokes for Different Folks
(3,616 Views)
12345qwertt,
It would help us in a situation like this if we had a bit more information about what you're doing.  Am I safe to assume that you're using a CVI OI?  TestStand 4.0?  Exactly what changes are you hoping to make to the report?  A description of exactly what you're trying to do will help us greatly in understanding the problem, which will lead us to a better solution.
Derrick S.
Product Manager
NI DIAdem
(3,593 Views)
