LabWindows/CVI
2's complement
I like to convert 0xFFFF ~ 0x8000 to -1~-32767 by use 2's complement method.
I was not able to find in the online help, could someone tell me:
1. How to do the 2's complement with CVI?
2. How to find these kind of information in CVI help?
Thanks a lot
(5,240 Views)
To get the the twos compliment of a number in C, multiply the number by -1.
CVI does not provide a great deal of information on the ANSI C programming language beyond the function panels.  But documentation on the C language is readily available on the web.  Use google or your favorite search engine.
Good Luck
(5,230 Views)
Signed integers are already represented using two's complement, so if you are only concerned with 16-bit integers (like 0xFFFF and 0x8000), all you have to do is cast the value as a short int. If you need to interpret other sizes, the general method would be this:
int highBitMask = 1 << (numBits - 1);
(~highBitMask & number) - (highBitMask & number);
(This assumes that number is a value who's two's complement value is within the range of [-2^numBits, 2^numBits  - 1].  That is, no bits above numBits are set.)
As far as finding help, you can search for specific topics in the CVI help by going to Help->Contents then typing keywords into the Index or Search tabs, but for things like data representaion or C language specifics, you're probably more likely to find what you're looking for in a good reference book or by searching the web.
Hope this helps!
Mert A.
(5,227 Views)
If I remember my maths correctly (its been a while...) you obtain the 2's complement of a number by first taking the 1's complement and then adding 1. So, in C:
int number;
int complement_2;
complement_2 = ~number + 1;
JR
(5,185 Views)
Thanks for all your replys, after 5 years not touching C & CVI, I'm rusted... Your helps really put me back to programming mode. Thanks.
FerroK
(5,177 Views)
