LabWindows/CVI
why GetPanelAttribute(m_iPanel, ATTR_SYSTEM_WINDOW_HANDLE, &hWnd) does not work?
hello, I load a panel via:
step1: m_iPanel = LoadPanelEx (iParentPanel, "uirfile.uir", P, __CVIUserHInst);
then I obtain the windows handle of the panel (m_iPanel) via:
step2: GetPanelAttribute(m_iPanel, ATTR_SYSTEM_WINDOW_HANDLE, &hWnd);
notice: if the first parameter (iParentPanel) in step1 is 0, step2 success, otherwise the hWnd always be 0.
is this a bug of CVI or should I do something else?
thanks advance!
(3,360 Views)
This is actual expected behaviour of the function. As is said in the help for ATTR_SYSTEM_WINDOW_HANDLE attribute:
Description:  A number that can be cast to obtain the system-specific window handle for a top-level panel.
    The actual type of the value is HWND.
    The value is zero for child panels.
(3,355 Views)
Thanks! Since I need a hWnd for a child panel, I would put parent panel parameter for loading a child always 0 even it is not. It looks work...
(3,337 Views)
