LabWindows/CVI
3DPlotSurface after changing the axes range, the surface doesn't update, while the lines do
I'm using CW3DGraphLib in Labwindows/CVI version 9.1.1 to create surface plots.
I have the following problem: after changing the min/max settings for any of the axes or applying autoScaleNow, the surface doesn't redraw to indicate the changes. If I use the Surface+Lines or Lines only surface style, then the lines do update but the surface doesn't.
Thank you.
(2,984 Views)
marinag,
Could you please provide an example program and code snippet that shows this behavior. In addition, screenshots of the behavior are very helpful if the issue is reproducible. Thank you!
Jared A.
(2,971 Views)
