LabWindows/CVI
SQL Toolkit Copy Records db1->db2
Occasionally, I want to archive records from 1 database to another.  No change in tables or fields, just copy.
Basically, I
Create Record (db2)
Fetch Next until EOF (db1)
PutRecord (db2)
This works, but it is incredibly slow.  Any suggestions would be appreciated.  I will post code later today.
Thanks in advance, Dave
(3,337 Views)
Hi Diverdke,
From what you have described this seems like the most efficient way to move that data. Do the records contain a lot of data? Or does the database have any scheme to keep records in a certain order? There are many factors that may influence performance and those could be hardware or software related. As I said previously the steps you are taking to move the record, in my mind, is the most efficient and straightforward way.
Patrick H | National Instruments | Software Engineer
(3,322 Views)
