LabWindows/CVI
A challengable conversion: translate Prec_##Type
Hi
  I'm working on non-ansi .c and .h libarary files, whick frequently contains Prec_##Type. The meaning of Prec_##Type for example is same as below
char *Type ="Every_2nd_Loop_Sec_W";
the value of Prec_##Type = sprintf(Prec_,Type) = Prec_Every_2nd_Loop_Sec_W      //pseudo code.
 I'm trying to use this librarys in CVI but hope never to change it. Since CVI does not recongize Prec_##Type, especially the character of "##", firstly of all I need to convert them into like sprintf(Prec_,Type). How can I do it? I think it's kind of precompiled skills.
The precondition:
1, never to change the library files
2, these files would be able to be reused by CVI
Best regards!
Jacky
Message 1 of 16
(9,170 Views)
Not sure what your program syntax is exactly, but the ## pre-processor token pasting operator is recognised by CVI and this works:
    #define join(x, y) sprintf (str, x##y)
    char str [256];
    join ("Prec_", "Every_2nd_Loop_Sec_W");    // str now contains the desired string
JR
Message 2 of 16
(9,159 Views)
Hi
  Thanks for your reply. Actually, that's not exactly what I want.
  Take an exampe below. I want to get  FixDefConst (100.0, Percent_W), and there's definition of FixDefConst(). I prefer to translate Min_##TypeName and Prec_##TypeName in pre-compile, or something like that. How can I do it?
typedef unsigned short                                              Percent_W;
#define Prec_Percent_W                                           (100.0 / 4096)
#define Min_Percent_W                                                     (0.0)
#define Max_Percent_W                                    (65535 * 100.0 / 4096)
#define FixDefConst(ConstFloat,TypeName) \
((TypeName) FactorRound (((ConstFloat) - Min_##TypeName) / Prec_##TypeName))
/* Limit final duty cycle to 100%                                   */
LfBSTC_Pct_WasteGateDutyCycle = Min (LfBSTC_Pct_WasteGateDutyCycle,
                                       FixDefConst (100.0, Percent_W));
Message 3 of 16
(9,108 Views)
I'm not sure what your problem is - your code compiles OK for me. (Although I could not cut-and-paste it directly to my CVI system - I re-entered it, with a little bit of simplification. Different PC.) Do you have a run-time issue?
Message 4 of 16
(9,109 Views)
Hi
The ultimate purpose in my example is to tranlate Min_##TypeName to Min_Percent_W, but never to assign/assume Min_Percent_W is an integer or string. According to your suggestion on using Join function, the type of Min_##TypeName is a string. Yes, I can use fmt function to convert a string to a number, but that is out of my expectation.
And what I want to do is to simply translate Min_##TypeName to Min_Percent_W before compile/linkage. By the way, in my program there're kinds of ##, like Min_##OldTypeName, Prec_##TypeName. I expect to translate them automatically.
Thanks!
Jacky
Message 5 of 16
(9,091 Views)
But your program already does exactly that! The pre-processor substitutes the correct text just before the compile step. I must be misunderstanding something. Are you trying to avoid using the #define Min_Percent_W statement?
JR
Message 6 of 16
(9,088 Views)
Hi
  I think I didn't explain my question clearly.
  Attached is the real head files I reuse. I include them in CVI and use  FixDefConst(5.0, Every_2nd_Loop_Sec_W). I don't want to modify these two head files, which contains ##. However, if there's no pre-compile treatment on them, error will be given when compiling. So I'm trying to find a way to translate ## before compile.
#include <cvirte.h>
#include "type_math.h"
#include "type_def.h"
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 FixDefConst(5.0, Every_2nd_Loop_Sec_W);
 return 0;
Message 7 of 16
(9,075 Views)
If you can attach the .h files to your next post, this might help us to see what the compiler doesn't like.
JR
Message 8 of 16
(9,067 Views)
ok, let's try to clarify.
the ## operator is treated by the preprocessor, which means it operates before the compilation. it is named the token-pasting operator: its purpose is to take whatever text is in left and right and make a complete token out of that. remember that the token is formed at the preprocessing: the token does not have a type at all, it is only text pasted in the source code, in the same way #define works.
jr_2005 gave an example, which was indeed using strings (note how the arguments to join() are surrounded by ""):
char str [256];
but the example works also for variable names:
#define int_min   -32768      // define some values
#define int_max   32768
#define float_min  -1e99
#define float_max 1e99
// the next line defines a macro which will allow to link the type name to the values defined
#define min( type ) type##_min
#define max( type ) type##_max
int main()
    int value;
    // how it works: when you type "min(int)" in your source code, the preprocessor will perform
    // a replacement: copy the source text of the argument, paste it and append the _min
    value = min( int );
    // so the above line is replaced by the preprocessor by this code:
    value = int_min;
    // int_min is a #define, so ultimately the preprocessor replaces it by its defined value
    value = -32768;
    // this last line is what is effectively passed to the compiler.
    printf( "the minimum value for type int is:%i\n", min( int ) );
token pasting is done before compiling, thus cannot be used at runtime. the following example will not work at all:
int main()
    char line[256];
    printf( "enter a type name: " );
    gets( line );
    printf( "the minimum value for type %s is:%i\n", line, min( line ) );
    // this does not work because min(line) is replaced before compiling by line_min, which is not defined.
Message 9 of 16
(9,062 Views)
Find attached.
Thanks!
Jacky
Message 10 of 16
(9,046 Views)
