LabWindows/CVI
A confirm popup problem.
I wrote some code to use a confirm popup. When I run the program, the popup windows shows but the text on the button looks strange. Instead the “Yes” and “No” it shows “&Load” and “Network...”  I made a new project, I got same problem. I reinstalled the CVI, problem is still there. How can I fix this problem?
(3,736 Views)
Accepted by someidea
I have the feeling you are dealing with the same problem as here except that you are on one machine.  Is it possible that you have another installation in another dirctory that your CVI is looking at?
(3,709 Views)
Thank you very much, problem solved!
(3,679 Views)
