LabWindows/CVI
ACTIVE-X CONTROL TO CREATE THE TABS IN UI IN CVI
Do we have any active-x control to create the tabs dynamically in cvi environment?
(3,665 Views)
Is there a reason why you cannot use native CVI tab controls?
Which version of CVI are you using? Native tab control was introduced in CVI 8.0, on previous versions you could use the EasyTab control. Both of them permit to dynamically create tabs or insert existing panels into a tab control.
(3,640 Views)
i am using automation tool to automate my UI,its recognising only activex controls
with 2013 version of CVI.right now i am using the method which was you suggested(Native tab control)
(3,633 Views)
Well, I'm afraid I cannot help you since I don't know any actveX tab control.
(3,630 Views)
Thanks Robert.
(3,627 Views)
