LabWindows/CVI
GetTickCount64 error using NI-488.2 functions
When executing the Send function in the NI-488.2 library, I get the following error:
“The procedure entry point GetTickCount64 could not be located in the dynamic link library KERNEL32.dll”
My development PC is running windows 7, Labwindows 2012, and NI-488.2 15.5. I am building a distribution targeting WinXP. I’ve read that WinXP does not support GetTickCount64, but according to NI, NI-488.2 15.5 supports WinXP. Has anyone seen this before?
(3,959 Views)
Hi Stephen,
Are you using Windows XP 32 bit or 64 bit? The NI-488.2 is only supported on 32 bit XP.
Best Regards,
T. Le
Vision Product Support Engineer
(3,905 Views)
Hi T.,
I am using Windows XP 32 bit.
(3,890 Views)
Hi Stephen,
Are you able to use any other functions without a problem or is it just this particular Send function? If you try using a native write function, like ibwrt, do you get any compiling errors?
T. Le
(3,876 Views)
