"Ado with datagrid"
"Hello,
I'm using Labwindows/cvi 6.0 and I've a problem when I try to atach datagrid to Ado data control (both activeX) in UI panel editor. Is not possible to attach DataSource field from Datagrid to Ado, I can't access DataSource field. Why? Is not possible to use it at design time?
I've tried to use programmatically but I have no idea how to use the function SetByReDataSource (from DataGrid), the third parameter is the control Ado. How can I pass it from the Ado ActiveX handle?
ps:I Don't have SQLToolkit.
- jecki
