LabWindows/CVI
ADO control with DBGrid control in CVI
"Ado with datagrid"
"Hello,
I'm using Labwindows/cvi 6.0 and I've a problem when I try to atach datagrid to Ado data control (both activeX) in UI panel editor. Is not possible to attach DataSource field from Datagrid to Ado, I can't access DataSource field. Why? Is not possible to use it at design time?
I've tried to use programmatically but I have no idea how to use the function SetByReDataSource (from DataGrid), the third parameter is the control Ado. How can I pass it from the Ado ActiveX handle?
ps:I Don't have SQLToolkit.
- jecki
(2,963 Views)
My knowledge on database programming is limmited, however it is possible that the "control ADO" parameter that you need to pass to the SetByReDataSource() function is a handle to the actuall database that you previously opened and get a reference to.
Another idea is to look for some code on the web for this; even if it is for Visual Basic or some other language it should be helpfull on understanding the programming of the controls.
Just my 2 cents....
Juan Carlos
N.I.
(2,963 Views)
