Videoman,
Each instrument that you communicate to has an specific "protocol" for communication. Most return actual string, but other return binary data that you have to read in a specific data type.
The first thing that here is to make sure that you are using the CVI Instrument Driver for the HP 53131A this will make things much easier and you may not need to worry about string conversions. You can find this driver
here.
Take a look at the documentation for the instrument or the driver to find out what is the data type that the instrument returns; based on that data type you can do the right casting to read the bytes in the right for
mat.
Let me know how this goes.
Good Luck
Juan Carlos
N.I.
Message Edited by Support on
04-03-2008 02:30 PM
