LabWindows/CVI
Access denied: This target is running a version of LabVIEW that is different than LabVIEW on the host computer. For Real-Time targets, you can verify the version and reinstall the Real-Time software using MAX.
Ho do I find the vesion of the real time softweare on the device?
cannot see device in NI MAX
Cannot see either of my devices in MAX
NI - CDAQ 9132  and NI-CRIO 9014
(5,698 Views)
Cannot install
NI-DAQmx 14.1 (higher version already installed)
NI MAX Configuration Support (higher version already installed)
Application Development Support (higher version already installed)
NI I/O Trace 14.0 (higher version already installed)
NI Measurement & Automation Explorer 14.0 (higher version already installed)
NI Web-Based Configuration and Monitoring 14.0 (higher version already installed)
(5,689 Views)
Hello, since this question refers to labVIEW you should post it in the LabVIEW board: this one is dedicated to LabWindows/CVI and its users.
(5,676 Views)
