LabWindows/CVI
Can I have clipboard shortcut keyevents sent to my cvi MainCallback Funciton?
After reading the post Ctrl - Alt Keypress, I wrote a program as below:
int panelHandle = 0;
WNDPROC currentWndProc = 0;
int main (int argc, char *argv[])
	panelHandle = LoadPanel (0, "test.uir", test);
	InstallMainCallback (EventFunc, NULL, 0);
	InstallParentWndProc ();
int CVICALLBACK EventFunc (int panelOrMenuBarHandle, int controlOrMenuItemID, int event, void *callbackData, int eventData1, int eventData2)
	if (event == EVENT_KEYPRESS)
		...........//codes trying to catch Ctrl+C/V keyevents and do sth.
LRESULT CALLBACK ChainedParentWndProc (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
	switch (message)
		case WM_KEYDOWN:
			if ((GetKeyState (VK_CONTROL) & 0x8000) && (wParam == 'C'))
				break;//can catch Ctrl+C here
			else if ((GetKeyState (VK_CONTROL) & 0x8000) && (wParam == 'V'))
				break;//can catch Ctrl+V here
		default:
			return (CallWindowProc (currentWndProc, hwnd, message, wParam, lParam));
	retrun FALSE;//or DefWindowProc//or CallWindowProc//doesn't make sense
int InstallParentWndProc ()
	intptr_t PanelWindowHandle;
	GetPanelAttribute (panelHandle, ATTR_SYSTEM_WINDOW_HANDLE, &PanelWindowHandle);
	currentWndProc = (WNDPROC)GetWindowLongPtr ((HWND)PanelWindowHandle, GWLP_WNDPROC);
	SetWindowLongPtr ((HWND)PanelWindowHandle, GWLP_WNDPROC, (LONG_PTR)ChainedParentWndProc);
Question is, I want to handle “Ctrl+C/V" keyevents in EventFunc so that I can get infos about both panels and control IDs, and do some own operations. I have run the codes and only ChainedParentWndProc can catch the keys. Is there any way passing special keyevents to CVI MainCallback?
Besides, can CVI swallow copy/paste operations?
Any suggestion is welcome and helpful, thanks.
Yours Fu.
(5,000 Views)
Ctrl+C and Ctrl+V combinations can be trapped inside the main callback with this code:
if (event == EVENT_KEYPRESS) {
	if (KeyPressEventIsLeadByte (eventData2)) return 0;	// Ignore first event of a dual-byte character
	modifierKey = GetKeyPressEventModifiers (eventData2);
	virtualKey = GetKeyPressEventVirtualKey (eventData2);
	asciiKey = GetKeyPressEventCharacter (eventData2);
	if (modifierKey == VAL_MENUKEY_MODIFIER && asciiKey == 'C') {
		// Your code here
		return 1;		// Swallow the event
	else if (modifierKey == VAL_MENUKEY_MODIFIER && asciiKey == 'V') {
		// Your code here
 Those events can be swallowed.
(4,995 Views)
Accepted by topic author dashenyilang
You should give us a bit more of your requirements, since there can be a problem handling Ctrl+C and Ctrl+V key combinations.
If you look at samples\userint\multikey.cws example program you will see that those combinations are not trapped if the active control is a string control: I suppose these events are handled at a lower level by the OS to manage cut-and-paste operations and are not passed to CVI (so no good for string, numerics and so on). They are received if the active control does not handle cut&paste, though (e.g. buttons, rings, graphs...).
Nevertheless, since cut&paste shortcuts are intended and used as "system" operations by normal users (I mean: people use them by default for C&P and it will be difficult to divert them from this road), you need to clarify what is your goal and define exaclty when and how to handle those key combinations.
(4,990 Views)
Got it! My truly question is just that I can't trap Ctrl+C/V combinations in numeric controls.SInce it's managed by OS, I'll find another way in my program.
Thanks for your reply RobertoSmiley WinkVery kind of you
Besides, maybe a little bug?Press Alt key and then:Alt.JPG
(4,969 Views)
I'm happy to help.
But I don't understand you comment about the Alt key: can you detail a bit more?
(4,909 Views)
