LabWindows/CVI
ActiveX, control does not support persistence
I've been having problems with editing of a project using the richtx32.ocx activeX control. The project was developed on a Windows XP SP2 system running CVI 7.1. When the project was ported onto a Windows Embedded XP SP2 running the same version of CVI, I get problems editing the rich text box control although the project compiles and runs OK.
When I attempt to edit the control on the UIR I get a message "This activeX control does not support persistence. You will not be able to copy, edit, or save this control"
I have tried different versions of the activeX control without success. Also I cannot add a new rich text control onto the form as this returns a message "ActiveX control error"
Any help please?
(3,488 Views)
Windows XP Embedded is not officially supported to run LabWindows/CVI . I would suggest the ActiveX error is related to XP Embedded.
Mark M.
National Instruments UK & Ireland
(3,457 Views)
