Advantech USB-4704 Frequency
Hi
Is there any way i can read a frequency with the Advantech USB-4704?
Help share your knowlegde
(3,610 Views)
Sure, just collect a block of data and use something like SingleToneInfo() from the Advanced Analysis library to give you the frequency.
Martin
Certified CVI Developer
(3,609 Views)
Hi Shako,
I would recommend looking at how to add a third party USB device in Measurement and Automation Explorer. The following tutorial should help you get started:
http://zone.ni.com/devzone/cda/tut/p/id/4478
Once you have established communication to your device, try looking at some of the example programs in CVI Help. To navigate to this, please go to LabWindows/CVI Help->Find Examples and in the Browse window, go to Hardware Input and Output. Communication with GPIB or VISA is a good starting point for a third party USB device. Good luck with your project!
Jackie
DAQ Product Marketing Engineer
(3,592 Views)
