LabWindows/CVI
Allocate memory for 2D arrays
What is the way to dynamic allocate memory for 2D arrays?
(4,433 Views)
Use calloc() or malloc() to dynamically allocate memory for arrays.
Arrays in C are stored with no overhead: there are no markers to separate elements, rows, columns, etc. An array is just a contigous block of data.
To use calloc(), you need to know the number of elements and the size of each element. calloc() initializes all memory to 0.
To use malloc(), you need to know the total size of the array. malloc() allocates the memory, but doesn't initialize it.
In either case, the sizeof() function can help.
If you're creating a 10 by 20 array of integers, you have 10*20 = 200 elements. Each element has a size of sizeof(int).
calloc() and malloc() both return a pointer to void. You need to cast it to the type you're using.
int *myPointer;
myPointer = (int *) calloc( sizeof(int), 200);
// or
myPointer = (int *) malloc( sizeof(int) * 200);
free(myPointer); //when you're done with the array
To treat the allocated memory as a two dimensional array, you'll need to do some pointer math.
See the attached example. See some additional examples here.
(4,420 Views)
If you want the ease of use and readability of a real 2-d array, you can take the extra step of allocating a second array of pointers into the first array which can then be used like a static 2-d array.
ex:
int i, numRows = 5, numColumns = 15;
int **array = malloc (numRows * sizeof (int *));
int *memory = malloc (numRows * numColumns);
for (i = 0; i < numRows; ++i)
array[i] = memory + i * numColumns;
// this allows this usage
array[0][0] = 3;
array[numRows - 1][numColumns - 1] = 4;
free (array);
free (memory);
An alternative to this is to allocate "numRows" arrays of "numColumns" elements but this causes the managing code to be a little messier.
Hope this helps,
Alex
(4,412 Views)
Oops!
should actually be
int *memory = malloc (numRows * numColumns * sizeof (int));
-alex
(4,413 Views)
Hi!
Sorry, but it does not work.
Especially the "// this allows this usage" section.
Here it is what could meet my expectation.
int i, numRows = 17, numColumns = 5;
char **array;
array = malloc ( numRows * sizeof(char*));
for (i = 0; i <= numRows; ++i)
array[i] = malloc (numColumns);
Whit this the "// this allows this usage" works fine.
(4,377 Views)
