LabWindows/CVI
Analyzing PCM audio samples
I have a need to recover frequency and level information from a PCM stream that has been written to a file.
The PCM data is 16-bit signed, little-endian, sampled at 8Khz.
What CVI functions (if any) can be used for such a task?
Brian
(4,983 Views)
Hi Brian,
To my knowledge there are no specific CVI functions that will accomplish this.
Manooch H.
(4,905 Views)
You should be able to read in the data portion of the file (skipping over any header such as may accompany a .wav file) into an array and then submit it to functions in the Advanced Analysis Library (you need the FDS version of CVI for these). PowerFrequencyEstimate() is just one of a number of functions you might find useful.
JR
(4,893 Views)
