LabWindows/CVI
Animated control button
Hi All,
I am using LabWindows/CVI 2012.
With this is it possible to create an animated control button in .uir to make it more attractive.
If yes, can any one send me some related doc/examples.
Much thanks for your time.
Rahul.
(4,617 Views)
I'm not sure if this suggestion is exactly what you are looking for, but CVI ships with a custom "animation control" that permits to create an animated control from scratch or out of a picture ring control.
If you search for "animation" in the example finder (Help >> Search example) it will point you to an example program that demonstrate its features; I suppose it is the same published here.
(4,608 Views)
Much thanks for your attention and help.
Rahul.
(4,592 Views)
