LabWindows/CVI
DLL interface with power point
me created one project in cvi 5.5 it contain a main project with  DLL, in tht dll at a time i can connect other application like VB, C++ ,is it possible to connect my DLL  to MS Power Point or MS excel or android Tab, i want Read or Write from DLL to external  world (ms excel,ms ppt)
(5,313 Views)
Hello there!
LabWindows/CVI can certainly connect with other applications such as Microsoft Word, Excel, etc. through ActiveX.
Here is some related documentation: https://www.ni.com/docs/en-US/bundle/labwindows-cvi/page/cvi/libref/cviactivex_automation_libfuncove...
You can also run some samples shipping with LabWindows/CVI, that are located in <CVI Install Directory>\samples\activex to learn how this technology interacts with LabWindows/CVI.
Also note, that version 5.5 is no longer supported. Check with the Product Life Cycle Policy page to learn more about this: http://www.ni.com/lwcvi/product-lifecycle/
Best regards!
- Johannes
(5,309 Views)
hello sir ,
you are telling that i cant use activex control in cvi 5.5 ?
Best Regards
neenunaanu
(5,301 Views)
Hello!
LabWindows/CVI 5.5 is a deprecated version. Upgrading to a newer version is just a recommendation.
However, ActiveX was supported by LabWindows/CVI 5.5, as you can learn from the Release Notes: https://www.ni.com/pdf/manuals/320689f.pdf
Moreover, the ActiveX samples (e.g. samples\activex\excel\excelevents97.prjsamples\activex\powerpoint\simple.prjsamples\activex\word\wordrpt.prj) are also included in LabWindows/CVi 5.5, which you can use as a starting point for your particular requirements.
- Johannes
(5,295 Views)
okay sir
thank you
(5,291 Views)
