LabWindows/CVI
Append file name using FileSelectPopup under Windows 7
I saw the following thread for the same issue in Vista, just wanted to make sure that this issue has been fixed for Windows 7 also before I upgrade to the latest version.
http://forums.ni.com/t5/LabWindows-CVI/Append-file-name-using-FileSelectPopup-under-Windows-VISTA/m-...
Karthik
(3,474 Views)
Accepted by Karkala
I ran across that issue when I was running applications built under CVI 7.1.1 on Windows 7.  I can verify that rebuilding the application under CVI 2009 SP1 and later CVI 2010 fixed the issue.  So you should be ok.
(3,469 Views)
(3,465 Views)
