LabWindows/CVI
Are there ANY Ni-DAQmx based C code (windows os) examples out there that can run without the need for CVI ?
It's appears that CVI is a requirement for the ANSI C examples that come with NI-DAQmx. Are there visual C/C++ (or any other plain windows c compiler based) examples out there that can work without CVI / LabWindows etc.?
Devor
(2,988 Views)
Hi Devor,
There are examples for C code with DAQmx and they can be found in this folder on your computer:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
These examples do not require LabWindows or CVI--CVI just makes it easier to program with.
I hope this helps!
Kim W.
(2,967 Views)
