LabWindows/CVI
Linking errors in Labwindows 2010
While trying to duplicate the Word report example program in Labwindows 2010 the following error occurs.
18 project link Errors
Undefined symbol '_WordRpt_InserTab@4' referenced in test2.c
Undefined symbol '_WordRpt_GoToBookmark@8 referenced in test2.c ...
What is the basic thing i'm missing to get this to link?
Message 1 of 10
(5,484 Views)
WordRpt_InsertTab() and WordRpt_GoToBookmark() are part of wordreport libray.
So you have to add wordreport.fp to your project.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 2 of 10
(5,458 Views)
Thanks...
Message 3 of 10
(5,448 Views)
I´m also getting the same error, and the instrument driver is included. What can I do? Thanks
Message 4 of 10
(5,322 Views)
Does your .c file have the code "#include wordreport.h" at the top of the file?
Message 5 of 10
(5,286 Views)
Here are the includes cut from the code
// Example program to demostrate using ActiveX Automation instrument driver to
// control Microsoft Word 9.0 and later.
// Includes
#include <cvirte.h>
#include <userint.h>
#include "word2000.h"
#include "toolbox.h"
#include <utility.h>
#include "worddemo.h"
Message 6 of 10
(5,276 Views)
These appears to be the includes in word2000demo sample project, which does not make use of wordrpt instrument.
Wordrpt sample project is the sample project that uses Word Report instrument and actually includes wordreport.h
Message 7 of 10
(5,268 Views)
What would be the least number of includes that would open Word  and create a new file results.dat  that is the example i want to start with. From there i can sort out all the other functions.  ie a console app the opens word and creates results.dat
Message 8 of 10
(5,265 Views)
It depends on what do you want to obtain. Are you using functions from Word Report instrument? So you need to load both Word Report and Word 9.0 object library instruments and include word2000.h and WordReport.h files. If you can limit your application to word interface only then you need one instrument and one include only.
On the other hand, .dat does not appear a typical Word file extension: how do you intend to create such file?
Message 9 of 10
(5,260 Views)
Good point...
right now we create a results.dat file and print it to a centronics dot matrix printer.    The printers are being replaced so the need to change the report.  So the requirement has to change to results.doc  so the we can print it
Message 10 of 10
(5,256 Views)
