LabWindows/CVI
Bug on StripPlot?
Hi there!
I found a bug??? on StripPlot. If I draw a spike whitch is way out of range.
Exaple: range 0...100 spike 100000. Plotted as thin line work OK
but plotted as fat line the trace behaves very odd.
I include small sample project.
I have CVI 5.5.1
In Win2000 this works OK also with fat line
Kari Yli-Tuomi
[Attachment StripTest.zip, see below]
(3,247 Views)
Hey Kari,
I am seeing the same behavior on my tests. In 2000, everything works as it should. But switching to 95, I see unexpected behavior in both 5.5, and 6.0 CVI environments. I will talk to R&D on this, but I think the only solution for now is to keep the thin line, or increase the range of you y-axis to better accomodate the data.
(3,247 Views)
