LabWindows/CVI
Why are some panel buttons not viewable depending on what machine an application is run on (different Sun boxes, PC Xterms)
Is there something in the Window sizing/X Windows/termdef that is set incorrectly?
(3,206 Views)
Could you give me some more info. What machines does it work on? Which machines does it not work on. Also, when you say it is not viewable, is that at runtime?
Brian
(3,206 Views)
"More info: This is at runtime (LabWindows/CVI 4.0.1).
Panel appears larger/buttons visible on Sun Ultra 2 and
PC running Hummingbird X-emulator. Not visible on a Sun Ultra 1 and Sparcstation 5."
(3,206 Views)
More info:
Ultra 2 that works running OS 5.5.1
Ultra 1/Sparc 5's running OS 5.6 or 5.7
(3,206 Views)
