LabWindows/CVI
Bytes available on serial port
I have a threaded application that reads the reads the number of available bytes on a serial port using the VISA API. I would simply like to read the serial port if the number of available bytes is greater then zero. When I use the viGetAttribute() function, it always returns zero. Here is my function below.
    int num_bytes;
    while((num_bytes = viGetAttribute(instr, VI_ATTR_ASRL_AVAIL_NUM, &num_bytes)) > 0)
        ErrorPrintf("Num bytes available = %d\n", num_bytes);
       status = viRead (instr, buffer, 100, &retCount);
       if (status < VI_SUCCESS)
          printf ("Error reading a response from the device.\n");
       else
          printf ("\nData read: %*s\n", retCount, buffer);
    return 0;
Am I calling this function incorrectly? I can send data over the port and verify it's being sent using a port monitor.
(4,890 Views)
I don't have my CVI system available at the moment, so I can't confirm this but at a guess I would expect the viGetAttribute() call to return a status word, not the number of bytes. So perhaps instead of :
    num_bytes = viGetAttribute (instr, VI_ATTR_ASRL_AVAIL_NUM, &num_bytes);
you need something more along the lines of :
    status = viGetAttribute(instr, VI_ATTR_ASRL_AVAIL_NUM, &num_bytes);
This would avoid overwriting num_bytes.
JR
(4,884 Views)
Yes, you are correct. I did notice my typo and corrected it and replaced the zero with VI_SUCCESS.
(status = viGetAttribute(instr, VI_ATTR_ASRL_AVAIL_NUM, &num_bytes)) >= VI_SUCCESS
I now need to fix the problem with stopping my thread correctly.
(4,857 Views)
Hallo map and jr_2005,
VI_ATTR_ASRL_AVAIL_NUM flag can be used in order to determine the amount of data in the input serial asynch. COM buffer, but what about determining number of bytes in output buffer ? Is there any VISA function which query number of bytes in output buffer ?
BR,
Milan.
(4,465 Views)
Milan,
With a question like this, the best approach would be to make a new thread for your new question, which I can see that you have done on this duplicate post.  Once you have done that, there is no need to post on 9 other threads to ask the same question.  Please see the duplicate post for the answer that SFK has given.
Eric K
(4,428 Views)
Sorry again Erick,
problem has been fixed.
Milan.
(4,418 Views)
