LabWindows/CVI
Windows font settings produce incorrect appearance
I have developed application using lab Windows (version 8). It is unfortunate that the newer version of Lab Windows is not compatible with the older one…hence I had to manually create new ring controls and some other adjustments. Since then, we’ve started  problems with fonts appearance. We looked here for solutions and applied many suggestions that we found in this forum, but the fonts are still not appearing same on all PCs. I have set fonts on all controls/text fields/labels/etc to Arial 13. I built installation and installed it on two separate PCs. They both have resolution set to  1280/1024, DPI settings normal, Font size Normal… but the fonts on the panels are not the same size. On one of the PCs they look normal and on the other one they look larger, which causes labels to extend over the LEDs, text fields, etc.I noticed that there are few discussions about possible solution for LabVIEW application ... Something about adding lines to .ini file…appFont="Tahoma" 13
dialogFont="Tahoma" 13
systemFont="Tahoma" 13
 Can something similar be done for applications developed by LabWindows/CVI? I hope that someone will have a good solution to this problems. Thanks!Mira
Message 1 of 1
(3,138 Views)
