LabWindows/CVI
VISA GetInQLen
  In the old RS232 communications I would use GetInQLen to determine the amount of data in the buffer, is there something similar in the VISA commands?  I am receiving data between 4 and 30 bytes long.  Below is the code I have configured to read in 4 bytes.  Is their  a way to modify it such that it could very to depending on how many bytes are in the Buffer?  I am assuming I am missing something simple.
 // Parse a binary string
 ViNullChk(RxPacket = (ViBuf)malloc(4));
 ViErrChk(viScanf(resourceName, "%4c", RxPacket));
(4,524 Views)
I normally don't use VISA, preferring the traditional RS232 library, but I've found an attribute that may help you:
viGetAttribute (handle, VI_ATTR_ASRL_AVAIL_NUM, &bytes);
(4,511 Views)
Thank you for the information, that is what I was looking for.  But as you stated I am thinking I will probably go back to the standard RS232 functions, I haven't seen the benefit of VISA for my applications.
Thanks.
(4,507 Views)
Hallo Roberto,
VI_ATTR_ASRL_AVAIL_NUM flag can be used in order to determine the amount of data in the input serial asynch. COM buffer, but what about determining number of bytes in output buffer ? Is there any VISA function which query number of bytes in output buffer ?
BR,
Milan.
(4,253 Views)
Milan,
With a question like this, the best approach would be to make a new thread for your new question, which I can see that you have done on this duplicate post.  Once you have done that, there is no need to post on 9 other threads to ask the same question.  Please see the duplicate post for the answer that SFK has given.
Eric K
(4,228 Views)
