LabWindows/CVI
C programming
hello everyone... i need help... i have made a hotel reservation program but i need help to save each time i fill it... because after each start the table is empty... how should i save the filled table?
besides another issue is that when i fill the table with strings, it complains that it should be double value... i changed it to char, but the char i fill is a string... how should i solve my problem?
i appreciate your help, thanks
(2,388 Views)
Do yourself a favor and click on your table control.  Then hit the F1 key on your keyboard. Up pops the most wonderful tutor for LabWindows: the Help window!
No, seriously.  Do that right now.  That's how I cut my teeth and so can you.
There are truly excellent articles on calling convention, examples, theory of operation, etc.
There are even example projects in there that will launch right from the Help...
(2,356 Views)
