LabWindows/CVI
CA_CStringToBSTR error
HRESULT CVIFUNC OpenSession (CAObjHandle objectHandle,
                                                  ERRORINFO *errorInfo,
                                                  const char *baseDir)
 HRESULT __result = S_OK;
 CableEyeCtl_ICableEye_Interface * __vtblIFacePtr = 0;
 int __didAddRef;
 int __errorInfoPresent = 0;
 BSTR baseDir__AutoType = 0;
           __caErrChk (CA_CStringToBSTR (baseDir, &baseDir__AutoType));
 __caErrChk (CA_GetInterfaceFromObjHandle (objectHandle,
                                           &CableEyeCtl_IID_ICableEye, 0,
                                           &__vtblIFacePtr, &__didAddRef));
 __caErrChk (__vtblIFacePtr->lpVtbl->OpenSession_ (__vtblIFacePtr,
Error:
 CA_FreeBSTR (baseDir__AutoType);
 if (__vtblIFacePtr && __didAddRef)
  __vtblIFacePtr->lpVtbl->Release (__vtblIFacePtr);
 CA_FillErrorInfoEx (objectHandle, &CableEyeCtl_IID_ICableEye, __result,
                     errorInfo, &__errorInfoPresent);
 if (__errorInfoPresent)
  __result = DISP_E_EXCEPTION;
 return __result;
I am trying to use the above, however I keep getting errors using  __caErrChk (CA_CStringToBSTR (baseDir, &baseDir__AutoType));
This is due to the CA_CStringToBSTR function returning No size info  which inturn gives  a -ve return value.
I have tried to use CA_CStringToBSTR ("string", &baseDir__AutoType)  --  It does the same
What am I doing incorrectly, please help
(3,766 Views)
Hi Slten,
Please can you use the function below to convert the error you are getting from the HRESULT function into a meaningful error code.
http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvica_getautomationerrorstring/
Please post this here so I can then investigate this further. Any addition information such as which version of CVI you are using would also be useful.
Many thanks,
Josh E
National Instruments UK & Ireland
(3,733 Views)
Thank you for the reply
HR= CA_CStringToBSTR ("string", &baseDir__AutoType);
This does give a HR= 0  seems to return no size info..though
The issue with my post has been resolved.  I used create Activex Controller instead or create ActiveX Server
(3,719 Views)
Ok, thanks for letting me know!
Josh E
(3,701 Views)
