LabWindows/CVI
CVI 2013 and switch statement default case
a
Review this code.   CVI 2013 gives me   "warning: will never be executed" at line XXX.
typedef enum bandType { Band900, Band1800, Band1900 };
int main (int argc, char *argv[])
  enum bandType band = Band900;
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 band = 512;   //  Line A,  not a normal use of enum but does execute
               // and sets the variable to 512
 switch (band) // Switch statement with an enum type
  case Band900:
    // Do something
   break;
  case Band1800:
    // Do something
   break;
  case Band1900:
    // Do something
   break;
  default:
    // Line XXX.  Execution can get here, despite warning that it can not
   break;
 I think the warning is wrong.
 My team uses the default case to throw an error for two reasons.  One is to catch if an enum is out of range.  Two is for future growth.  We can expand the definition of the enum (for example add Band2100).  If a section of code is not updated for the expanded enum, than the default case throws an error message.
 I think I have seen a similiar issue with an if statement, though I am not completely confident.  Example:
 if( str(x) < 100)
  // Do something,  but I got the warning here
 Your thoughts please
(7,393 Views)
When investigating your case in the interactive execution window I came across the following behavior:
enum zahl { EINS, ZWEI, DREI, VIER };
run in the interactive execution window gives two errors about invalid allocation size...
(7,387 Views)
I think that "band = 512;" is undefined behaviour not covered by the C standards. A perfect compiler could warn there. But no compiler is perfect and a warning isn't required by the standards.
The warning for the case statement is ok in my opinion because the default case depends on the undefined behaviour before.
(7,368 Views)
Hi Wofgang,
Can you give additional details on these two allocation size errors?  If you could provide an exact snippet to recreate them, that would be most helpful.
I am not seeing these errors in the Interactive Execution window when I make a similar declaration.
Daniel
Edit:  I found your follow up post here: http://forums.ni.com/t5/LabWindows-CVI/Interactive-Execution-fails-miserably/td-p/2613011 .  It appears this issue will more than likely be included as a fix in our next release.
Daniel Dorroh
(7,290 Views)
