LabWindows/CVI
CVI 2013 can not generate dll import library
I try to use the "Generate dll import library" to generate a VLC's lib file, the process is not popup any error or warning, but the generated lib file just have 2K size. Obviously, the tools do not get the lib file correctly, because when  compiling the  source, compiler give an error of undifined symbol.... But if using cvi 2012, the import library can be generated correctly. I think mabe this is a bug of cvi 2013.
David Lee
(3,905 Views)
Hi David,
You mention "VLC's lib file," but I'm not sure to which file you are referring.  VideoLAN produces many LIB files for various projects.  Can you either post the library to which you are referring or direct me to a download location?
Thank you,
Daniel
Daniel Dorroh
(3,830 Views)
