LabWindows/CVI
CVI 2017 (but not CVI 2015) crashes if you try to convert a .uir containing an ActiveX control to .tui format.
I didn't see this one on the list of 'known issues'. To recreate the minimal case to see the issue:
1. Create a new .uir file.
2. Add an ActiveX control (I used Microsoft Web Browser).
3. Attempt to convert to text by selection Options ->  Save in text format...
4. Complete the save dialogue.
5. CVI crashes with the message "Labwindows/CVI has stopped working. A problem caused the program to stop working correctly. Please close the program."
The crash also occurs on save when the 'auto-save to .tui' option is turned on.
The issue doesn't seem to be present in CVI 2015. I haven't tried any other versions.
This issue appears to occur on both Win7 and Win10.
(2,534 Views)
Just noticed this bug has been reported already. Don't know if there's a solution yet, though.
https://forums.ni.com/t5/LabWindows-CVI/CVI2017-Crash-when-saving-a-UIR-with-an-ActiveX-control-as-a...
(2,522 Views)
Hi !
The CAR number is #659599, I have tracked the bug and probably in a future release, the bug is going to be fixed.
(2,496 Views)
