LabWindows/CVI
Visa Time out ZVH
I try to remote control R&S ZVH using Visa.
The command IDN pass ok and i have the identity of the instrument.
Aloso the command init pass ok.
The problem is with the other SCPI commands that helps to configure the instrument, I can send them but while i send "Query" there is an error time out Visa for reading.
I can increase visa time out for reading but nothing change.
Here is the link of the instrument manuel: https://cdn.rohde-schwarz.com/pws/dl_downloads/dl_common_library/dl_manuals/gb_1/z/zvh_1/ZVH-K40_Rem...
Could you help me .
Thanks a lot.
(4,000 Views)
Hope everything is fine, unfortunately, I don't have the R&S ZVH but did you try the common commands on page 34 or the problem is only with some commands to configure the instrument? Did you check the Baud Rate?
 Have a great day.
(3,953 Views)
Hello
Thank you all !
The problem was resolved
The licence was expired
Thanks NI
(3,920 Views)
Accepted by topic author xmouth
Hi!
Thanks for letting us know about the result! It great to hear that know is working!
Mark the post as resolved.
Have a great day.
(3,909 Views)
can you send to me an image of your programme,i have trouble with scpi on labview
(3,690 Views)
