LabWindows/CVI
CVI 5.5.1 , SQL Toolkit 2.0.1 Problem with DBImmediateSQL
I am having problems with the SQL toolbox - more specifically the "DBImmediateSQL" function. When the line of code runs which contains this function, it returns the error code -11, and an Automation Error code, Member unkown.
(3,255 Views)
Hello sensitec,
I would suggest trying the workaround in the following forum post.
Hope it helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,251 Views)
