LabWindows/CVI
CVI 7.00 panel scaling problem.
There are a couple of threads in the group that refer to a problem with
scaling the contents of a panel when it is resized. The discussions have
involved UIRs with table controls.
However, I have a UIR without a table in which the problem occurs.
On resizing the panel I get an occasional message popup with the
following text "the attribute value passed is not valid".
The UIR uses EasyTab functions to create tabs from a canvas and contains
various control types but no table.
A previous contributor reported something similar in an application
involving a coms callback and no table. My application also has a coms
callback.
I can remove the scaling option as it isn't essential but I'd prefer a
better fix if there is one.
John Cameron.
Type softly, read gently.
(2,877 Views)
It looks as though the fault occurs if the scaling takes place when the application is in the coms callback.
John C.
(2,848 Views)
