LabWindows/CVI
how to detect fatal error with SQL TOOLKIT functions
I use the SQL Toolkit 2.0 with labwindows CVI. 7.1.1
My problem is how to detect cable disconnection (or database loss of connection ) when using SQL Toolkit functions.
DBConnect returns error code and its possible to dectect this problem.
But when a connexion is established, the DBRefreshParams() or DBExecutePreparedSql() functions for example return a FATAL RUN-TIME ERROR.
There is a solution to intercept the error code returned by this functions ?
( Or to avoid application interrupt ).
thanks.
(3,538 Views)
You could try pinging the server before executing critical functions: InetPing () function is available in cvi 7 in the Internet library.
(3,534 Views)
I always use this function at regular interval to detect a disconnection.
But the problem will be the same even if I call the inetPing() function before a call to the SQL Toolkit function.
A disconnection can occur just before the call an stop my software.
I call the NI Support to know if its a SQL library bug ...
(3,507 Views)
