if you can afford a little time gap between consecutive measurments and your signal is not transient,
you can always take a short 'test-measurment' before, with max. gain,
then calculate the optimal gain setting which will fit without overload
and then use that value for the actual measurment.
simple way of 'autoranging'
Once the game is over, the king and the pawn go back into the same box.
