LabWindows/CVI
CVI 9.1.0 crashes when looking at variables window
Uploaded as CVI_variable_crash_debug.zip
Message 11 of 13
(1,044 Views)
We've found the problem, and it will be fixed in a future release. The crash occurs when you are suspended and have the variable display window open under the following conditions:
1) You have one or more ViSession variables, and
2) your program does not call viGetAttribute, and
3) the path to your EXE/DLL is somewhat long.
The easiest way to work around this issue is to add a call to viGetAttribute to your program. It does not need to do anything meaningful -- it just has to link. We're sorry for any trouble this has caused you. Let us know if you have further questions.
Mert A.
Message 12 of 13
(1,031 Views)
haha, quite an interesting crash case.  Well thank you for replying.
Message 13 of 13
(1,002 Views)
