LabWindows/CVI
CVI-Built Installer Run an Executable After Installation
An installer built in LabVIEW can be configured to run an executable after installation (see here).
I've been using this feature for years to installa didditional drivers and so on...
Is it possible to get the same behavior for an installer built in CVI 2015 SP1?
I don't find how to configure it.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,223 Views)
Accepted by vix
Hello vix,
In the Files tab of Edit Installer Dialog right-clik on the executable and choose <file_name> Options ...
Then in Installation File Options dialog you can check "Launch after Installation"
(3,219 Views)
