LabWindows/CVI
CVI Client communicates with PLC (Siemens) via Modbus
I am think of linking an existing CVI programm running on a PC to a siemens PLC using the modbus protocol.
- Has anybody experience with such an application?
- Any idea about the time effort required to implement such an communication solution with/without the NI OPC server?
- Any examples or code available? - If we could buy some standard code/modules the solves the problem or that may be adabted we'll probably do that.
Thanks for your help - it's much appreciated!
(3,708 Views)
We successfully integrated communication to a S7 plc via rs232 in an application of ours.
If this is your case, I can send you some source code (you'll have to adapt it to your needs and to the messages effectively interchanged with your actual plc). Just let me know.
Roberto Bozzolo
(3,708 Views)
Hi Roberto
thanks for your answer. I'm still waiting to get the specs of the PLC - if it's the right one I certainly appreciate if you could send me the code.
Meanwhile, I wonder
- how long did it take you to implement your solution (ca.)?
- did you use the NI Industrial Automation OPC Server?
Thanks for your answers!
Regards Reto Meili reto.meili@msemeili.ch
(3,708 Views)
Hi Roberto,
I am also trying to access PLC S7 200 through NI CVI 5.5. I am having NI OPC Server.
I understand that u have done it successfully. Can i have the procedure or some .c codes for doing this.
regards,
Amit Kumar
Project Engineer
AED, ARAI
Pune, India.
amit.aed@araiindia.com
(3,708 Views)
