LabWindows/CVI
distribution kit creating directories and subdirectories
Distribution Kit: I am adding a file in File Group which resides within a subdirectory. When installing software the subdirectory does not get created but the file is added to the application directory. How can the subdirectory be created??
(2,977 Views)
If I understand corectly, you need to use the "Relative Path" option on the screen where you define your groups. The catch is that the groups are just lists of files, independent of their source path. If you need certain files in a folder on the target machine, make a special group for them and use the "Relative Path" option.
(2,977 Views)
Excellent!
Thanks-
(2,977 Views)
