LabWindows/CVI
CVI Distibution with Database Functions
I am working with CVI2012.  I have an application that uses the SQL toolkit.  I made a distribution and installed it on a target machine (Windows 7 with the CVI2012 runtime engine).  However when I install the application on another target (also a Windows 7 machine and also with the CVI2012 runtime engine) I cannot not initialize the database.  The application fails on a call to DBInit(DB_INIT_MULTITHREADED).  I get an error of -100: DB_FAILED_TO_LOAD_DLL.   (I am using  SQL Anywhere 11.)  I know that the ODBC configuration is the same on both targets and I can access the DB manually through Interactive SQL.
I am baffled by this.  After some searching I found that the file "cvidb32.dll" was not in the system32 directory so I copied that over.  Still no joy.  (I would also expect this to be installed when I installed the RTE.  I did not have to manually copy this file on to the computer where the application does work.)  I have checked the forums here have not found a solutionl.  One post discussed running sqldistsupp.exe after the installer.  I tried this and got an error "Driver's ConfigDSN, ConfigDriver or ConfigTranslator failed in function SQLConfigDataSource".  Another post suggested simply adding CVISQLShared.msm to the installer.  I tried this but it did not fixt the problem.  I also tried downloading the SQL Distribution Toolkit help and it turns out the file has no content under the help topics.
Clearly something is missing but I don't know what.  I tried running Dependency Walker to find the missing DLL but it did not show anything was missing.
Thoughts?
Thanks.
(5,134 Views)
I have not distributed any applications with sql functionality, but looking at the following links it seems it can be a little tricky:
Why Do I Get Errors When I Try to Run a Distribution of a LabWindowsâ„¢/CVIâ„¢ Program Which Uses the SQ...
LabWindowsâ„¢/CVI SQL Toolkit 2.2 Readme
S. Eren BALCI
IMESTEK
(5,127 Views)
It looks like I missed that I copied "cvidb.dll" to my target instead of "cvidb32.dll".  When I put the cvidb32.dll file in place the application started working.  However I still don't understand why the file was not put in place by the RTE installation.
(5,124 Views)
SQL Toolkit is an add-on library that is sold and licensed separately.
Maybe that's why it is not included in default run time.
If the previous post "solved" your problem, please mark it as a solution.
S. Eren BALCI
IMESTEK
(5,113 Views)
