LabWindows/CVI
CVI: IMAQ Vision objects only possible via separate window?!?
I use LabWindows/CVI and IMAQ Vision library to aquire and edit images from a camera.
Is there any way to display an IMAQ vision image object other than via a separate window?
I do not want to save/load image files. This takes too much time...
Robin...
(2,827 Views)
See the following document for more information:
Image Display Methods
Another option if you have the CWIMAQViewer Object for Visual Basic you can use this on you user interface in CVI.
Met vriendelijke groet / Kind regards,
Karsten
(2,806 Views)
