LabWindows/CVI
CVI Real Time Graph Issue
Hi All,
Need some help related to plotting graph in CVI real time mode.
First i ran the code in normal mode ( without using RTMain(), sleepUS() & running on local desktop computer), and i got the desired graph. After that i ran the same code in real time mode means changing the "Target Type" to dll, target i have given real time PXI chassis ip address, under "Target Settings" i have mentioned Runtime support as "Real Time Only". In real time mode, i didnt get the expected graph. I am very confused and not sure what went wrong.
Any help is greatly appreciated. Is that anything to do with SleepUS() function?
Haari
Message 1 of 1
(3,342 Views)
