LabWindows/CVI
CVI Real-Time Trace Toolkit 2.0 Issue
I just recently purchased teh CVI Real-Time Eecution Trace Tool 2.0 software.  I have run the utility and have a problem.  The Function Events display only shows the TraceStart and and TraceStopAndSend functions.  Is there something special that needs to be setup in order to display the function information?  I am using the following to configure the tace utility:
TraceConfigure (1, 1, 0, 2500000, NULL);
Any advice?
Message 1 of 9
(5,095 Views)
Did you enable tracing? (Target settings / Real-time function tracing )
Nicolas
Message 2 of 9
(5,087 Views)
I believe so.  I am capturing traces.  The thread view is working fine.  I just don't see any function trace information besides the two functions I mentined above.
Message 3 of 9
(5,084 Views)
Are you sure you should have recorded events?
Have you tried TraceUserEvent?
Nicolas
Message 4 of 9
(5,079 Views)
I am using the TraceUserEvent function.  The events are "flagged" in the thread traces.  I just don't see and function traces.
Message 5 of 9
(5,076 Views)
Did you enable "user-defined functions and library functions" for real time function tracing in target settings ?
Are you using an external compiler ?
Are you calling InitCVIRTE before calling TraceXxx functions?
Nicolas
Message 6 of 9
(5,045 Views)
I am using CVI 8.5 to compile the code.
I call InitCVIRTE() as the first order of business in RTmain().
I do not understand how to enable "user-defined functions and library functions" for real time function tracing in target settings.  As I stated in my orgainal post, I am calling TraceConfigure() to setup the trace settings.
Message 7 of 9
(5,033 Views)
Build / Target Settings => there is the real time function tracing control (above 'embed project uir')
Nicolas
Message 8 of 9
(5,029 Views)
That's it!  I completely missed that setting.  I will go give it a try.
Thanks!
Message 9 of 9
(5,026 Views)
