LabWindows/CVI
Installed IMAQ, now missing an fp file
We installed NI-IMAQ 8.5 onto a WinXPSP2 system running CVI 8.0, and now we get the following error popup when we start CVI:
Warning: Cannot find program file for library.
Library: "MAX configuration library"
Function panel file: "C:\Program Files\National Instruments\CVI80\bin\nimaxconfig.fp"
Anybody know what this is?
Menchar
(3,253 Views)
Hello Menchar,
This MAX Configuration Library allows you to configure data, generate system reports, and parse MAX error strings.  Try doing a windows search for this file.  If you can not find it on your computer you will need to re-install any driver that installs MAX (NI-DAQmx).  If it still does not find it in the new location or after you've verified it's on your computer you can fix it in CVI by going to Library>>Customize and editing the path for the nimaxconfig.fp entry.
Let me know if this does not fix your problem.
Kristen
(3,228 Views)
